Old 11-28-2007, 04:06 PM   #3 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Originally Posted by 95metro
So it's just the torque difference between the 3 and 4 cylinder that makes it bearable with the 4? Any possibility of keeping the 3-cylinder final drive and just changing the 3rd, 4th, and 5th gears to smaller sizes?
It's all about the torque. I guess that's possible. But where to get the gears? Also, that would mean taking the tranny apart, which is slightly scarier and requires special tools, I think.
A straight swap should theoretically only take a couple of hours:
- remove starter
- detatch steel lower rad tube bolted on top
- disconnect clutch cable, reverse switch wires, speedo cable
- remove axles
- support engine
- unbolt & remove tranny
