Old 04-25-2009, 06:54 AM   #1 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
Sharing Garmin code
Hi,
This is a quick Perl hack used to convert the Garmin data file into text records that can be loaded into excel. Once in excel, macros can convert and reduce the data to useable representations:
#!/usr/bin/perl
# trace <file>
# This program decodes a Garmin nuvi trace data file.
# Found in the GARMIN\GPS\Current.gpx file.
open(FH, "<Current.gpx"); # Get the file
while ($line = <FH>) # Read all lines
printf("%d\tlength\n", length($line)); # Report size
# Convert raw block into records
$cc = index($line, ">"); # Find end of first record
while ($cc >= 0) # Pass through until all records found
$cc+=1; # Add ending, delimiter character
printf("%d\t%s\n", $cc, substr($line, 0, $cc)); # Each field
$line = substr($line, $cc, length($line)); # Grab rest
$cc = index($line, ">"); # Find end of next record
if ( length($line) > 0 ) # Check for any left-over text
printf("%d\t%s\n", length($line), $line); # Finish
printf("\n"); # Extra space to improve readibility
close(FH); # Done with file
# end source
There appears to be two legacy XML constructs that include a binary "NULL" character. This causes the read loop to see three blocks of text, not one huge block. Regardless, these legacy text are written as text records even though I don't have any use for them.
Macintosh and Linux systems have Perl but a Windows user may need to find a Perl system. The typical scenario is:
  1. Mount the Garmin on the computer with the USB cable
  2. Copy the 'GARMIN\GPS\Current.gpx' file to a directory with the Perl program
  3. Run the Perl program and redirect the output into a text file
  4. Use excel (or equivalent) to load the records
My plan is to add subroutines to assemble the trip data, <trkseq>, into files of tab delimited, data points, <trkpt>, with the format:
time_stamp - day and fraction
X axis miles - relative to the left or western most longitude
y axis miles - relative to the bottom or sourthern most latitude
mph - calculated from the preceding and following points and times
altitude - meters from GPS data
Another routine will extract the way-points with the names and X and Y axis miles. Eventually, I'll combine the trace data with the checkpoint so we can identify the start of each "coast down" segment, the ultimate goal.
Bob Wilson
Local record
