Old 04-25-2009, 02:14 PM   #5 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
I can't see if you have a coupe or a 4-door. If the latter, you can make a little fairing that goes on the door, and matches the contour of the fender skirt. On a coupe, most skirts I see would benefit from big overlaps starting at the body side, not the existing flare at the wheelwell itself. You can get a sharp edge on Coroplast with a hair dryer or heat gun and gentle pressure, the better to smooth the transition. That's more rugged than a carved edge.
