Old 11-28-2007, 04:07 PM   #5 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Originally Posted by 95metro
They were lighter, maybe even more underpowered, but were the gears identical? Maybe look at putting the old Firefly tranny in the blackfly? I thought I read somewhere that there were some slight transmission variations besides final drive.
Lighter, less rotating mass (12 in wheels & tires); also the pre-86 cars EPA ratings were higher, even though they used the same test method (they introduced a "fudge factor" and changed the ratings even though the cars didn't change).
As for the gear ratios, everything I've learned about those trannies, I learned at TeamSwift. If I recall rightly, all the 3-cyl cars had the same ratios, but used different final drives depending on: XFi/12 in rims/13 in rims/convertable (heavier).
Some bedtime reading...
http://www.teamswift.net/viewtopic.php?t=14845
http://www.teamswift.net/viewtopic.php?p=163307
http://www.teamswift.net/viewtopic.php?t=23748
