Old 04-26-2009, 12:58 AM   #29 (permalink)
Ernie Rogers
Ernie Rogers
Thanks for the article
Thank you , Frank,
For showing me that article. It's hard to know for sure what the effect is unless you measure it yourself. I personally did not notice any change on my last tire replacement.
I think the author forgot to mention an important point. When you get the new tires, you will probably drive faster--if you keep the speedometer at the same position as before since the tire diameter is greater. This change in speed would have a greater effect on mileage than the effect from having thicker tread.
Ernie Rogers
