Old 04-26-2009, 04:07 PM   #8 (permalink)
Ryland
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
yes, that light blue vehicle is one two electric cars I own, it's a 1975 Seabring Vanguard, Citi-car, like what TomEV drives, the electric car that I drive every day is a later version, of that car, a 1981 Comuta-car, I don't have any good numbers on the energy usage of it because my batteries are 2nd hand and in rough shape so I've been leaving them on the charger more then I would normally to keep them topped off and to equalize and desulphate the plates, I'm also using the original on board charger from 1981 that does not turn off, it just tapers the charge slowly as the batteries get closer to full, this makes it hard to get exact numbers on energy usage, but if I had to make an educated guess based off Kill-a-watt meter readings at the outlet.
Ernie I would like to see, based off your math, what kind of mileage you think my electric car gets, with my current lead acid batteries I would say I can go one mile on 250-300 watt hours, or about 3-4 miles per KWH as it comes out of the outlet, before the charger.
So what does that come out to in MPG? and at what point am I losing that 50%?
