side cars are hard to set up so they handle well as you have the same kind of alinement problems you get with a car, only it's on a semi-removable part of the vehicle, not an easily removed part of the vehicle either.
Side car motorcycles are also normally designed to have a side car, something like the Russian made Ural, where their front suspension is set up differently so they handle better with that 3rd wheel.
I would say get a motorcycle trailer, it would also work with your metro if you had a hitch on it, they tend to be small, light and let the cycle lean in turns, you can also un-hook it for short trips.
