Old 04-27-2009, 11:15 AM   #15 (permalink)
theunchosen
I would be hesitant to use whitening tooth paste.
Its actually got some nasty side effects if you aren't careful. For example if you leave the stuff on your skin for extended periods(not residue but if you rubbed it against your arm on accident in the bathroom) it will burn your skin.
The whitening compound specifically if you talk to your dentist or your dermatologist they will tell you not to leave it on your skin. I discovered this combating acne and then had to go to the doctor again to do something about the skin.
I would bet paste with "refreshing crystals" would be your best bet as that stuff feels like sandpaper if you rub it off.
