Old 04-27-2009, 03:25 PM   #7 (permalink)
DonR
YJ - '89 Wrangler
FOCUS - '00 Focus ZTS
The Wife's Hot Rod - '09 G8 GT
Last 3: 23.22 mpg (US)
I know they say the Volt's generator does not charge the batteries. They say it was an inefficent use of the gasoline. Go figure.
Maybe - It's not automatic, but i'm not an electric kind of guy.
Generator with adjustable voltage regulator for your different vehicles.
Have main disconnect switch for the battery bank.
Disconnect batteries then start the generator.
I would think the controller would treat it like turning it off then back on again.
You man be able to have an AC output so you can do a little charging of main batteries when at stop lights/coasting.
Good luck
Don
