Old 04-28-2009, 12:23 PM   #3 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Yes - it's in the "MORE" menu. The offset for your speedometer/odometer is under the "SPEED" option.
I have mine adjusted because I'm not running the OEM spec tire size for the transmission in my car (though I swapped transmissions, not tires).
With your larger tires, your speedo/odo will be reading low, so you'll have to use a positive offset in the ScanGauge to compensate.
