Old 02-17-2008, 08:40 AM   This thread is in the EcoModder Project Library | #1 (permalink)
krousdb
Ecomodding Amateur
krousdb's Avatar
Cold Fusion - '04 Prius
90 day: 67.34 mpg (US)
Prius aero mods (undertrays, grille block, mirror delete...)
Note: see also Autospeed article: adding a chin undertray to a 1st gen Prius
This is the 1st gen Prius tray.
I did this about a month ago....
Compare to the Prius undertray in this article: Autospeed article: adding a chin undertray to a 1st gen Prius
At least we are on the same page.
Yesterday I kicked it up a notch.....
Prius Rear Undertray Rear View. The drivers side does come with a tray (diffuser) but the passenger side is open due to the complication of the muffler and exhaust. I used a screw thru the coroplast about 1" long that rests on the muffler to keep a gap between the coroplast and the muffler. From the rear, the white coroplast was quite visible. The green paint was all I had. I also ran out of coroplast. Once I get more I will do something less piecemeal and paint it black. I have yet to go for a drive. Hopefully nothing falls off.
