Not sure if I can explain this idea well enough but I will try. Put the motor at the top portion of the hinged part. Run a wooden rod down the center and attached to one side of the gear on the motor. The rod would be attached to the flaps and allowed to push the flaps open. This would require it to be attached by some type of hinge to allow for angle change. I am not sure how to control the motor. Hope this helps.
