Old 04-30-2009, 03:05 AM   #3 (permalink)
Allch Chcar
Ethanol Fan
Rangerpowersports has a guide on electric fan conversions. A/C bypass is necessary if you have A/C. For the temperature, you'll want whatever your Thermostat is, stock is 195 degrees.
The electric conversion kits are NOT cost effective. If you can do it yourself with a pulled part you'll see a benefit, otherwise it's just for show.
~Allch Chcar
