Old 04-30-2009, 10:40 PM   #5 (permalink)
allc0re
allc0re's Avatar
The Truck - '00 Ranger XL Ext. Cab
90 day: 24.94 mpg (US)
Send a message via AIM to allc0re Send a message via MSN to allc0re Send a message via Skype™ to allc0re
Originally Posted by Allch Chcar View Post
Rangerpowersports has a guide on electric fan conversions. A/C bypass is necessary if you have A/C. For the temperature, you'll want whatever your Thermostat is, stock is 195 degrees.
The electric conversion kits are NOT cost effective. If you can do it yourself with a pulled part you'll see a benefit, otherwise it's just for show.
Thanks for the info. I'll check Rangerpowersports.
I bought the relay kit for $35 and the fan came from a yard at $35 also(if I remember correctly), so altogether that's only $70 bucks in this. I should recoup the money in about 2 years of driving if gas stays at $2/gallon.
I'll try to take some pics of my progress and final setup.
