Old 02-17-2008, 08:03 PM   #2 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
The main reason the mileage went down in '95 and up is because the body style changed, and the cars got significantly heavier.
I doubt there's any difference between the '94 ECU and the '95 ECU. In '96 the cars got OBDII, that's where the biggest difference would be seen.
Here's my advice:
Keep the '99 ECU specifically because it will permit you to use a ScanGauge in the vehicle (the SG requires an OBD2 computer). Using a ScanGauge to fine tune your brain and right foot will reduce your fuel consumption dramatically more than any ECU swap you could possibly make!
