Old 05-02-2009, 07:05 PM   #15 (permalink)
jamesqf
Originally Posted by theunchosen View Post
Are you suggesting that I can't stick a turbine into an extremely hot flow and get work?
The critical word there is "flow". Why do you have a flow? Pressure differential, no? And in most turbines, you've created that differential by heating something (by burning coal in the case of a powerplant) thus raising the temperature & pressure. But if you're using exhaust heat from the powerplant to make a nice warm environment for your bacteria, there's not going to be any PT differential.
As to the sulfur compounds. . .that happens when you burn coal.
So what exactly happens to the sulfur in the coal? You don't suppose it could be oxidized to SO2 in another exothermic reaction?
