Old 05-05-2009, 02:30 AM   #2 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
Welcome to EcoModder.com
This is a good idea, since most new cars have tons of electronics, instead of the good old mechanical odometer.
Originally Posted by savefuel View Post
I installed a SIGMA bike computer (ca. USD 49.-) with a magnetic sensor attached to the left front wheel for accurate speed and distance reading.
My advice would be to attach to a rear wheel. The front wheels usually go a longer distance because of turning and slipping.
(of course the circumference of that wheel has to be properly measured and inserted into the bike computer!)
Calibrating a bike speedo is easy with a GPS:
First, set your wheel circumference (usually in millimeters) to what you estimate is right. Drive around with a GPS and then compare the distance with the speedo. If the speedometer is x% lower than the GPS, then input a circumference x% larger. The farther you go, the more accurate the calibration.
Piwoslaw's Peugeot 307sw modding thread
