Old 05-05-2009, 12:44 PM   #3 (permalink)
metroschultz
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Put your motor after the trans, and use the trans in neut to remove engine friction from the equation.
The engine can be OFF and the truck will drive under electric power until you decide to use gas. No oiling worries either.
For short trips you would use electric alone and for longer trips you could switch to gas when pack voltage got too low,
Then use the gas engine to charge the batteries while you were on your way to Grandmas house.
Once you reach Grandmas, you then have a full pack to run around town and get the can of cranberry sauce you forgot.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
