Old 05-05-2009, 05:42 PM   #48 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
OK, I did a test run and hypermiled my best EOC technique, also did a coastdown test to compare with base values.
Coastdown test, multiple runs in each direction
February was without blocks and tail.
May is with blocks and tail.
Feb 25, 2009 - May 5, 2009
10.0 - 15.6 seconds 60mph to 50mph, 156%
13.0 - 19.0 seconds 50mph to 40mph, 146%
18.0 - 26 seconds 40mph to 30mph, 144%
21.0 - 36.2 seconds 30mph to 20mph, 172%
Scangauge Report
May 5, 2009 Trip
$2.42 Cost
29 mph avg
63 mph max
2.3 hours
3250 rpm max
68.5 miles
197 F water temp
1.15 gallons
59.2 mpg
This was a lot of work and careful careful accelleration followed by long coasts. It is going to be tough to match this, there were some long drawn out coasts to work my way up to 59 mpg. However, with additional mods, I am certain I can beat 60 mpg. I might have gotten 60mpg this time if I had stayed out for another hour and ran some more country roads.
103% over EPA, if I calculated that right.
Nissan Versa Aeromods
