Old 05-05-2009, 06:58 PM   #9 (permalink)
Hasbro
Hasbro's Avatar
Originally Posted by rkcarguy View Post
I'm playing with designing a similar setup via autocad. With the mid engine design there is enough room to take the area between the rear wheels and ramp it up to the tail at a more shallow angle than off of the rear tires. The angle can then be blended into the sharper angle off of the rear wheels if you don't want to lengthen the rear end.
May want to consider a widebody bugeye sprite fiberglass kit to begin with, the shape is close to what you want with the bugeye's(headlights) and tail chopped.
Would love to see your work. Are you a LocostUSA member?
Yes, there will be a tray underneath. I need to find an article that showed a new undertray with a circular modification in the center that helped top end speeds quite a bit (smoother flow), looked very simple. Anyone seen that article?
Which Bugeye kit are you referring to? There was a factory works fast track body or are you referring to a bugeye racing body? Pics?
Originally Posted by vinny1989 View Post
Looks good.
May i ask - what program are you using to create those drawings?
Paint. Yes, rough.
