Old 05-05-2009, 08:15 PM   #5 (permalink)
Peter7307
Originally Posted by dcb View Post
Microwave it
Actually for small amounts of water the microwave can be more efficient, since you don't have to heat the pot or kettle. Not sure where the break even point is.
I would do the same.
Actually heating a small amount of water is a real nuisance.
I have an electric jug but it needs about three cups and normally I only need one cup hot for tea or coffee so the microwave is the clear winner.
I know it still uses coal generated electricity but here gas is used for heating houses etc and coal for generating power.
I suspect that will change as time goes by and we switch to more renewable sources.
If the choice is gas on stove top or electric jug and the pour into pot ;I think your choice of electric jug is the better option.
There is some chance of using renewable energy and the overall efficiency would be higher as well.
As an aside why are electric jugs not better insulated?
The one I have is about as hot to touch as the contents are.
Maybe a combination of thermos and electric jug would work.
Any thoughts?
Cheers , Pete.
