Old 02-18-2008, 02:10 AM   #93 (permalink)
boxchain
I'd rather be biking
boxchain's Avatar
Beater Hauler - '92 Pickup
Lexie - '98 Civic LX
90 day: 39.46 mpg (US)
Rentaclipse - '08 Eclipse ?
90 day: 28.28 mpg (US)
Awesome project! If I keep seeing projects like these, I may start aeromodding myself!
Originally Posted by AndrewJ View Post
After having it on the car, I've decided that I'm going to try to find a hinge to put on the front part of it tomorrow. A hinge will greatly facilitate tire removal if (when) I get a flat.
Save yourself a lot of trouble (and weight), where you drilled out holes in those brackets, take a dremel or equiv and cut a channel out of one end of the hole:
|C
Now you can remove them with 1/2 turn of the screw, lift and the bracket should pop off and you won't lose the screws
My bike runs on dihydrogen monoxide.
I like to use these acronyms
