Old 05-09-2009, 02:11 PM   #6 (permalink)
aerohead
kammback
The boattail on the T-100 has fenestrations for the existing tailights which can be seen from the rear.Covered with plex,and at a 7-degree angle they are clearly visible from behind and for oblique viewing,there are reflectors at the back for added visibility,and the license plate is there with dual illumination.--------- I don't have a high confidence that an "open" tail would perform close to that of a closed structure.And Sepp has demonstrated that an open-at-the-back structure doesn't perform as well as a completely sealed unit.
