Old 05-11-2009, 07:31 PM   #52 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
Originally Posted by CapriRacer View Post
The problem with arguing rubber "hardness" and trying to relate it to rolling resistance is that tread rubber compounds have a three dimensional relationship between rolling resistance, tread wear, and traction - and unfortunately "hardness" is only 2 dimensions.
So you can have a "hard" compound that has high rolling resistance, poor traction, but good treadwear and a "soft" compound that has high rolling resistance, good traction, and poor treadwear.
In other words, you can't relate hardness to rolling resistance.
(And BTW, you can't relate rolling resistance to traction or grip either)
Apparently you haven't been following the discussion.
more info based on solid tires
http://www.rehab.research.va.gov/jou...kauzlarich.pdf
