Old 05-13-2009, 01:42 PM   #5 (permalink)
Bullockracing
Icarus - '011 Mustang GT
90 day: 20.71 mpg (US)
Originally Posted by binarycortex View Post
Try doing the speed limit everywhere, you will probably pick up more MPG's especially with that gas sucking V8. Keep in mind, the slower the engine turns, the less fuel it uses. So as long as you are in the high gear you'll save gas at slower speeds, provided you aren't lugging the engine.
Yeah, the gas-sucking V8 [car] is gone. The Mustang didn't have any onboard mileage devices, but I know it did very poorly at low speeds. Anything over 35 mph was a cruise in fifth gear. I think the motoring horsepower required just to turn the motor at whatever speed was in excess of the required amount to move the car. I did measure (A-B-A comparison) that the Mustang got the same mileage at 55 as it did at 70.
The Fusion is an automatic, and it won't go into top gear below 45 or so, since the throttle load will keep the transmission in a lower gear, or at least out of lockup (not sure which) above 45 or so she gets very happy at low rpms.
