Old 05-13-2009, 07:02 PM   #6 (permalink)
LeanBurninating
EcoModding Punk
LeanBurninating's Avatar
Honduh Power - '98 Civic HX
90 day: 44.37 mpg (US)
Welcome to the boards!
+1 for the throwout bearing story.
If you are lazy like me, just go into neutral without using the clutch. Its pretty easy to do, you basically just have to eliminate the load on the tranny, which means the engine is not accelerating or decelerating the car. So maybe 10% throttle or so. Depends on your car (truck?) but to get a feel for it, take your foot off the gas, pull on the shifter a tad in the direction of neutral, and give the gas pedal a gentle "blip" and it should pop right outta gear. Easy.
