Old 05-13-2009, 06:51 PM   #70 (permalink)
brucepick
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.67 mpg (US)
Re. "gains from lift".
Oops. So far as I know, the act of creating lift by aero effects by necessity demands power from the system and does not give any benefit, unless you're trying to get off the ground to fly.
Actual weight reduction helps of course - because the engine now has less mass to accelerate. Merely reducing the force of the wheels against the ground by lift (or by a whole bunch of helium balloons) does not reduce the car's mass. So the engine's job is not easier.
Of course it takes energy to lift part of the car's weight off the ground, which ultimately comes from your engine and your fuel. From what I've read here before, that penalty occurs as drag. All other things being equal, a car with more lift will have a higher drag coefficient. Nuttin' comes from nuttin', and NSTAAFL: no such thing as a free lunch.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
