Old 05-13-2009, 09:13 PM   #32 (permalink)
yetimus
Originally Posted by dcb View Post
Yup. Do you know if your 96 passat ecu plugs look like that? And if pin 9 is what is connected to the mpguino? (and which one is the vss?)
Sorry for the delayed response. Yes, after checking the Bentley, the consumption signal is located on ECM pin 9 on my '96. The VSS, again according to Bentley, does not go to the ECM. It feeds through the firewall directly to the cluster - which is where I tapped it.
Not sure if my ECM plug is similar to the one you posted. FWIW, the schematic indicates a 68-pin plug on the ECM.
