Tuning Your MegaSquirt
According to that 0.2ms/V variation in opening time is what they put for a default number. So for a 2V drop the injector opens 0.4ms slower.
Your numbers might vary slightly but that should get you pretty close. Just change your opening time when taking the alternator off/on and you should be set.
Edit: I'm slow posting so use dcb's numbers
