For all but the shortest glides, I use neutral. I don't want to put wear on the the throwout and my clutch is hydraulic, I don't want a slow bleed of pressure to slip the clutch. Notice how the brake pedal goes down when the master cylinder has a pressure leak? My car actually uses half of the brake fluid reservoir for the hydraulic clutch.
moorecomp
Mancelona, MI
