Ya, pics of the car with the shocks/springs to give a sense of how the car sits.
Do you know if the springs are the same spring rate as stock, or stiffer? I know you said "normal shorter springs" but would be interested in more info there. You mentioned load carrying as a reason for switching back; how much of a limitation do you have currently?
Appreciate the info
