Old 05-15-2009, 11:20 AM   #5 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I have no idea what version it is. The only problem I did have with it is that it did reset itself twice while driving. Once the day before, and once on the trip where the display problem occurred. I haven't had it hooked up all that long at all.
It was also not in a case. I simply had it double sided taped to the steering column with a little bit of tape.
If you simply think it needs to be reflashed, I can do that. I have a duemilanove sitting on the desk upstairs that can be used.
If you think that shipping it back to you would be a lot easier, I can do that too.
