There's no problem or wear moving OUT of gear without the clutch. All you're doing is pulling the gears apart. It's going into gear where it might be an issue.
I can do clutchless shifting if I want to, but usually I use the clutch.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
