Thanks alot for all good comments.
That the engine goes into fuel cut-off when when coasting in gear, is that also for diesel?
I could never have figured out that putting a gearbox in neutral without clutch and then gear back to 6th after would be more healthy then holding the clutch down.
So for a diesel:
Coasting in gear for breaking
Coasting with clutch in for short distances
Coasting with neutral for long distances
