At those dimensions you gave me MPaulHolmes, the case would dissipate a little less at 25C temperature difference. Of course, now that seems extraordinarily high.
25C - 142 watts
20C - 113 watts
15C - 85 watts
10C - 57 watts
5C - 28 watts
This assumes 1/4 inch Lexan – 1/2 inch would dissipate half as much heat.
To me the main point in favor of a lexan (or anything else nonmetallic) case would be the fact that it would be electrically insulative. Of course there's other ways to do that – for instance painting the aluminum case with something hard/nonconductive, like epoxy.
Is the emergency cutoff relay still present? Would grounding out to the case be detectable, leading to a disconnect?
