Old 05-15-2009, 07:57 PM   #14 (permalink)
daqcivic
daqcivic's Avatar
Daq Civic - '92 Civic DX sedan
90 day: 42.54 mpg (US)
The Hardbody - '91 D21 (pickup)
Originally Posted by NachtRitter View Post
I think I missed something ...
The brake temps they need to achieve remain constant and that is not a significant challenge in itself, that is why I said the end goal is not brake cooling. Their end goal is downforce, which requires greater aero efficiency of the rear wing, which requires smoother airflow across the length of the body. The brake ducts create turbulence in that airflow, so if they can make them smaller (while still cooling the brakes) the rear wing will be able to generate more downforce.
The wheel covers are not there to reduce drag across the outer surface of the wheels (even if they do that); they are designed to allow smaller brake ducts—improving brake cooling efficiency—which in turn improves the aero efficiency (downforce generation) of the car overall.
