Old 05-18-2009, 12:14 PM   #11 (permalink)
janvos39
janvos39's Avatar
FKB - '03 Focus DAW/FFDA1/5PFDMW
90 day: 45.7 mpg (US)
Manual actuated clutch on Burgman. I think this can be done by making some special shaft parts for a clutch out of a bike with manual gearbox. Probably the actuation of the clutch has to go through the center of the shaft due to the location of the external bearing for the shaft.
Another thing is the load on the clutch mechanism. Since you cannot put the gearbox in neutral, this mechism must contain a decent bearing.All the time for a stop the clutch needs to be used.
