Originally Posted by janvos39
Manual actuated clutch on Burgman. I think this can be done by making some special shaft parts for a clutch out of a bike with manual gearbox. Probably the actuation of the clutch has to go through the center of the shaft due to the location of the external bearing for the shaft.
Another thing is the load on the clutch mechanism. Since you cannot put the gearbox in neutral, this mechism must contain a decent bearing.All the time for a stop the clutch needs to be used.
This is true. Although I would already the lever in place if I were to go with a hydraulic clutch, merely combine the 3 braking systems into the right lever and use the left for the clutch.
I needs to get me a big giant socket to get that clutch loose.
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on
Facebook!
