Old 05-19-2009, 11:04 AM   #20 (permalink)
Mogal
Metro
Mogal's Avatar
Guzzler - '09 Accent GSI Sport
90 day: 32.55 mpg (US)
Originally Posted by doviatt View Post
Mogal, Did you get yours stabalized? Have you tried changing the switch? Your idle should read well below 1000 if it sounds like a normal idle.
Edit: Oh by the way Mogal. You did end up with the correct tach source. The brown or brown/black wire is the negative side of the coil which is what the tach expects to read.
I never had an issue with the tach reading incorrectly, just slow to repond.
Mine reads correctly at 850rpm at a warm idle.
Wiring was fine as well, although I never hooked up the dimmer wire.
Glad you got it going!! you'll enjoy them!
If yea can post pics!
Shift your Attitude
