Old 05-19-2009, 12:39 PM   #16 (permalink)
NeilBlanchard
Mica Blue - '05 xA RS 2.0
90 day: 47.48 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
An interesting variation on this was used in the Ducati SuperMono -- instead of using a fuel injector that sprays a mist; they used an injector that sprayed a single stream of gas, aimed right at the center top of the piston. The fuel hits the hot metal piston crown and vaporizes -- and it cools the top of the piston better than an oil mist on the backside.
The size of the piston/combustion chamber on this motorcycle required them to do this; and they ended up with a (counterbalanced) single cylinder engine that can rev up well over 10K RPM.
