Recent I made a modification on the front fender to improve the flow around front wheel and scoop. At the first test ride it became clear that the engine was faster on temperature indicating that less air is captured by the scoop.
On the FE I gained approx 2 %. The graph shows a decending line with ongoing modifying. Last two readings are with the modified front fender.
