Thread: Muscle Car MPG?
Old 05-21-2009, 02:25 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
You might be able to swap in a stick shift and clutch pedal for a few hundred too, and get lower ratio rear end gears. Add a kill switch, pump up the tires, and work on your technique.
Follow the gear change with some aero if you are up for max benefit per $, but then it might not look to stock though.
