I'm wondering about doing an underbody tray. I'm kind of concerned that limited airflow will cause the transmission and exhaust to heat up more then it is designed to. As far as i know, my manual transmission has no cooling whatsoever other then passive air flow. And with the exhuast i'm concerned that trapping a lot of heat under the car could cause a fire.
Thoughts?
