Here's a question for you guys. I have a bunch of the low voltage landscape lights laying around my garage, the kind that use a 921 type bulb. I was thinking about disconnecting the power souce since it's only a 12 volt converter anyway and connecting them to a car battery and then connect the battery to a solar charger. If i changed the bulbs to 194's which are only 1.5 watts or even leds, what size battery do you think I'll need and what type/size of solar battery charger do you think I need to get?
