Old 05-24-2009, 12:26 AM   #11 (permalink)
Peter7307
Originally Posted by Piwoslaw View Post
So I guess draining the tank just before a storm would be a good idea.
What about ultraviolet? Would dropping a UV lamp every now and then get rid of whatever is causing the smell?
Only if whatever is causing the smell is alive like an algae or something similar.
If it is coming from residues left by chemicals or whatever was held in the tank before you got it then probably not.
Worth a try though.
Might be an easy fix.
Pete.
