If you add a smoke colored plastic lense in front of the LCD it should help with the glare and sun light I think moving it back from the lense will also help. I have a digital dash in my chrysler and it uses the same display. The instrument cluster has a dark tint to it and it is shrouded some by the dash board. This may help. As for the Voltage regulator I do not know as I have no schematic but maybe a seperate one for the display. I would like to use a larger display as my eyes are not as good as they use to be any ideas??
Hugh
