Old 05-25-2009, 05:25 PM   #1407 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
Eric, you are funny! I tried out a completely new ISR with a separate timer that runs at 2 kHz. It went really really bad. hehe. I sampled the current in that ISR, still did the rolling average and even tried to do a rolling average for the throttle, just because I was messing around, and I wanted to see what would happen. Each second, it would be a pulse that was almost as if the motor was being shut down. It would drive normal for almost a second, and then that pulse again! Weird!
Good point about the usart stuff. That DEFINITELY doesn't belong in any ISR.
I think I need to sample the current during each pwm period, which is kind of bad because it eats up so much of the system resources. That's 2/3 of all computing time gone! But I guess it's worth it. Throttle is only needed at maybe 1kHz frequency or perhaps 500Hz. Maybe inside that ISR, I could take turns with current and throttle? Maybe skip a current sample every 16 times, to allow time for throttle? And then every 32000 times or so, skip both current and throttle to take temperature? Then, there should be 1/3 of the processing time avalailable for "other things..." Duh Duh Duhhhhhhh!
If I do throttle and temp outside, maybe that would be fine! Maybe just set a flag inside the ISR that says "timeToReadThrottle", and then I get to it when I get to it? I would have to disable the interrupts when I got to the throttle conversion moment so nothing weird would happen, but that's OK! I might try that! heck ya dude! You can't teach that, it's instinct! hahaha!
YO, STEINER! I think that would be really really helpful! I'll write out the directions for the etching and drill hole coordinates and drill hole diameters and etching width and who knows what!?
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
