Old 05-25-2009, 08:29 PM   #2 (permalink)
theunchosen
Do you have any torque numbers off the engine? They ought to be stamped somewhere? Well they usually are lol.
Its AC unless its got something that gets hot when you plug it up(not turned on).
I don't know that it would be a very good golf cart motor. . .golf carts are pretty freaking heavy. The batteries are enormous and heavy. The 3/4 hp won't do much good against a normal cart. If its lightened alot then it should be fine as long as you aren't planning on using it on the highway or roads. . .
