Old 05-26-2009, 10:44 AM   #14 (permalink)
mobythevan
HX1 - '98 Civic HX
90 day: 48.08 mpg (US)
PriusG2 - '09 Prius II
90 day: 47.91 mpg (US)
PriusG2-MFD - '09 Prius II
90 day: 50.3 mpg (US)
I did the calculations with what I believe is the correct injector size for the HX and came up with: usec/gal = 315451000
I figured I would start with that and see which way I need to adjust it. You box looks good. I am not sure what I would do with the wires to be more discrete. Did you connect to the VSS signal in the engine compartment at the transaxle connector? I haven't had time to work on my install yet, hopefully soon. Good luck on the calibration, looks like you'll be having some fun now.
Prius MFD fuel Log
Prius Gallons at fill up Log
