Old 05-26-2009, 12:20 PM   #13 (permalink)
doviatt
doviatt's Avatar
Grey Goose - '89 Metro LSI 4 door hatch back
90 day: 59.36 mpg (US)
Originally Posted by hu_man View Post
I would like to reflash the pic but I have no Idea how to do it. I downloaded the arduino 11 program but have no clue as to how to make my computer and the pic to comunicate with each other I sure could use some help here.
Sorry, Hu_man I didn't mean to hijack with my giddiness. Hu_man had a request for help that doesn't look like he got a response to.
Hu_man did you find a solution? a link to help your situation?
Back to my selfish hijack...but related.
I could use similar guidance for re-flash how-to and also could use help finding a correct VSS on my Metro. I measured the assumed VSS after my guino locked up and found over 12V "ouch" on it. Should have measured before I started the car with the guino plugged in. (Note: MPGuino came up and was working. I ran through the setup screens, then I started the car and it froze). I used the link (VSS values for many models '86-'95 (Rostra Precision Controls)[6]) from the wiki for the cruse control data and it said yellow/green '91 Metro. Mine is '89 yellow/green appears to be rear defrost relay.
Anyway with a re-flash and a correct VSS source I should be up and going.
Thanks (in advance) for your help guys.
